It doesn't matter if the are SKF, Timken or any of the name brands original Ford used would be better. The ones that were failing a few years ago were a name brand,this was mentioned in several tech articles in V8 Times. Problem was that the rollers were good,they knew how to duplicate Ford on that part but not the ends or the cages,they failed and ruined the axle housing bearing surface. I have bought rear brake drums that I thought looked good or knew they were low mileage just to harvest the bearings,wide five or up to 1948. I have found the article explaining rear wheel bearing failure. It was in Dick Flynn's Tech Tips,page 9 March April 1997 Early Ford Club V8 Times.. Although I am not a Dick Flynn fan especially his constant promoting of Amsoil productcts and his recommendation of synthetic rear wheel bearing grease,I do think he had something on this heads up. The bearings in question were a name brand Federal Mogul,the bearings failed and ruined axle housings because of non hardened side rails,supposedly Fords were hardened or tempered. Guess I would make sure if you insist on thinking that new and name brand are better,check side rails with a file.
