Not really the answer you are looking for but very few buy the repros as the originals are almost always okay as long as they have grease on them. If they are not, it is easy to find another pair.
I wish that were the case in my world. I would guess that 75% of the ones I see have a worn axle race, a worn hub, and a bearing that the case-hardening is worn thru from lack of lubrication.
Synchro - I’m at a decision point now as I am having new bearing races pressed onto the axle hubs. I’m planning to re- install the original bearings and hubs, but, if too loose, also have the repair sleeves for the hubs and V8 bearings if necessary. My only concern is what I’ve read about the V8 bearings being too hard. Any insights to share ?
Thanks - Jim
Not really. I haven't heard of the rollers being too hard until this thread. What is supposed to be the problem with them being hard? I know that for a while, the sleeves for the housings were too soft and wore quickly. Maybe someone has got things backwards and thought that because the sleeves are wearing, the rollers must be too hard when it is actually the other way around. The sleeves are too soft. That said, I believe some of the better suppliers have improved them recently.
Brent, I know the wear you refer to but I don't think it is due to lack of lubrication. I suspect that Henry's hardening process was lacking. It seems the metal at the open end of the hub bearing hardened OK but the it didn't get right down into the hub, leaving it too soft, hence the wear. It has been the same with every original hub I have seen.
So long as the female taper is OK, I am happy with one of those hubs after I use a repair sleeve in it and new end on the housing with V8 rollers. Alternatively, I pack 3 X NU 1010 bearings in each side.
