Bruce Adams
Has anyone pumped grease into the rear wheel bearing alemite/zerk fitting with the hub being off?
Is it supposed to ooze out of the race like on a ball joint, or does it crawl out like on the speedometer cable?
I had dutifully greased my rear wheel zerks every six months, but one was dry, two years after bbeing new and greased, so following replacement and bearing greasing I did this excercise and saw nothing coming out. I cleaned the race/axle space with a wire in case of blockage and still nothing, following maybe thirty squeezes with the grease gun while watching it. There is no grease from the rear end in the area, so my outer rear end bearing is probably working well.
Any thoughts?
Thanks.
Any thoughts?
Thanks.
