BLACKNRED
Is there a press fit hardened sleeve and undersized wheel bearing for the 32 to 48 rear differential. OD of Housing bearing surface is 2.06".
I know I can get a sleeve that needs machining of the old bearing surface and uses a standard wheel/hub bearing.
Hoping to avoid this.
Cheers
Cheers
