I think you need to use the newer bearing that is used in the repair of model A worn hubs. Look in the Brattons catalog at the repair of hubs section at the very first part of the catalog. They sell a sleeve that goes into the worn hub then you use the later size bearing which has a the same inside dia. but a smaller outside dia. Check it out.
