3-3/16 is listed in the 36 service bulletins for the same bearing the A uses, and there is a sleeve that is used to use the later 36 bearing to correct a worn hub, the area where the seal goes shouldn't have any wear, you can use that to compare, in other publications .010 has been used for wear limits for the axle housing, if your hub and axle wear are less than that it should be ok
