Early to Mid 1929 Coupe Step Plate Bracket Hardware before they attached the square step plate to bumper bracket.
Looking for the correct hardware to attach the step plate bracket to the rear crossmember and to the bolt that holds the rear fender bracket. The hole in the rear crossmember is approximately 5/8 inch diameter and the corresponding hole in the bracket is approximately 3/8 so apparently a flat washer was used. I could not find the specs for the flat washer bolt, washer, lock?, and nut that was used.
Also the bolt that holds the rear fender bracket that now must pass through the step plate bracket. Does anyone have the specs on this fastener.
Could not find this info in hardware book or JS.
Would really appreciate your help - Thanks - Hunter
