Restoring a 31 Coupe with rumble seat. My top (shortest) rear spring is broken, rest look good. Just wondering if there would be an issue running without the one leaf ? Would appreciate any opinion. Thanks
The top leaf usually has a chamfered edge to fit the inside of the crossmember. If yours does, and you eliminate it, the next leaf may not sit properly in the crossmember unless you chamfer it.
