Pilotdave
While chasing a light body lean to the driver's side, I discovered that some of the nuts on the rear spring u-bolts (8 leaf spring) were finger loose. Also that the u-bolts are too long so that the cotter pins don't pass through the castle nuts when nuts are tight. I'm planning to re-work (or replace) the bolts to eliminate that issue.
I did some exploratory tightening using lock washers until I can correct the u-bolts. Given the lean, I tightened the passenger side nuts first, then the driver's side. The passenger side center bottom plate is snug against the cross member. However, there is about 0.25" separation between the driver's side center bottom plate and the cross member. The lean is pretty much gone.
So a couple of questions:
1. Should there be any gap between the cross member and either center bottom plate? (I'm going to check the height of the plates to make sure that the correct ones are installed.)
2. If there is a gap, what's needed to eliminate it?
Thanks much.
Dave
Thanks much.
Dave
