1930artdeco
Ok, got the diff and new springs in. According to the manual it should diff, metal spacer holder, rubber spacer, spring, rubber spacer, metal spacer holder then shock pad.
Now my 57 wagon didn’t come with any of these spacer things. I am going to add them IF they should be there from the factory. My questions are these:
1) if installed, how does the diff keep from shifting front to rear? Will the U bolts keep it from sliding?
2) how do I install the top metal spacer holder? I can install the rubber pad, just not the spacer as it would force the diff spring pad to sit up about 1/8”.
Thanks.
Mike
Thanks.
Mike
