JRHASZARD
Talking about 1939 pickup rear spring center bolt. Using the correct square head bolt from Roy N. It seems like the head should slip into the square hole in the crossmember. I would propose the hole provides relief clearance for the bolt head, but also serves to prevent the spring from shifting laterally. I want to use a padding between the top of the spring and underside of the crossmember at the contact area. I purchased this material from Roy also. I am thinking about cutting a center piece out of this strap to provide clearance for the bolt head. Will the u bolts compress the strap material enough to allow the head to protrude into the hole? Has anyone done this? The strap looks like stiff canvass like the frame/body webbing for a Model A. My intention is to protect paint and avoid future corrosion. Thanks.
John
John
