... the left rear parking brake lever broke on me when I was crimping in the cable ...
I will get it welded this weekend ...
They were 'crimped' above the cable. That is all I was trying to do-nothing to tight just enough to keep the cable in the lever.
100% correct. The cable just lays in the "U" shaped trough and is held in place by the little spring. I never knew one to jump out in my 50 plus years of driving.They are designed to use as stamped. The cable will stay in the opening if installed correctly, it is the correct cable and the cable is adjusted correctly.
