hardtimes
I agree. I am very happy with the Panhard Bar on my '30 Town Sedan. Been on ~2 years now.
You better be right, my friend, about being happy, as you convinced me !
Just ordered from Snyders (..insert yellow face) !
Not saying it won't work, but I don't think there is enough room behind the axle with the spring and all there to do as you propose. The bumper brackets are in that area also. If you look at my pictures you will notice that my Panhard Bar is actually in front of the spring.
I don't know if the Model A suspension travel is enough to make a difference either.
Looks like something for your next project...![]()
Ok, I've done the 'job' and have a couple questions for YOU (yellow face) !
The (Snyder) instruction sheet says....'THERE IS A HOLE IN THE BOTTOM OF THIS FRAME BRACKET THAT ALIGNS WITH THE HOLE IN THE BOTTOM OF THE FRAME RAIL'.
My first question to you is...what did you do when you came to this ? My frame has NO hole (on either side of frame) ? Does you frame have such hole ?
FYI..I called Snyder's and spoke of their instructions and my 'no hole' situation. I do not want to have to drill any hole(s) in frame...unless necessary for INTEGRITY of strength of mounting bracket !
Second question: the 'BAR' hits/touches (where it crosses) the mount that you attach to the differential case. In your case/opinion is that a problem ?
hardtimes, I installed mine and had no problems with clearance. Yes, I had to drill the hole in the bottom of the frame, but I couldn't see how a little grade 5 5/16" bolt could hold up so I drilled mine and put in a grade 8. In fact I used all grade 8 bolts. Oh and BTW, the center section turned out great! Thanks again for helping me out with that.
Hardtimes, I honestly don't remember drilling a hole in the frame. I probably did but don't remember. I can't imagine why there would be a hole in the frame there originally.
Second question? I just crawled under my car to check and there in no way the 'BAR' comes even close to hitting. I can stick my finger between the closest point between the bar and mount. After being on the car for ~2 years there is not a mark on it. While I was under there I checked all the bolts and they are all still tight. Could you add a washer to space it away from the mount?
I'd like to give you pictures, but something has just happened that I can not post pictures here, after doing so for many years, go figure ! Also, can't put smiley faces up any more..now that really hurts, eh (yellow face here) !!
Hey Dennis,
Are you saying that you have already installed that rear that I supplied and that this is a picture of the housing ??
Wow, you are quick and it looks great !
BTW...You have installed the washers just like I did, AND just like the written instructions !
Yeah, I'll have to drill the 'HOLE' also (grade 8). I also had some minor hardware problems, but went to the junk coffee cans filled with junk fasteners. All went well after 4 hours. Hey, I'm old and slow remember !
One caveat. Ever hear of Murphy ? Well , this unit is very nice....but one 1/8" hole 'burr' stuck up and that's where I grabbed hold of the thing...whaah !
Hey Dennis,That's the one. The bearings didn't require a lot of shims so the width was near perfect and the pinion race was a good tight fit also. Btw I adjusted the for the length of the bolts on the sides of the center section to be the same as original bolts so they aren't too long or too short. I don't remember what the provided bolts were as I replaced everything in the kit to grade 8. No problem posting pictures, I just post them direct to this website from my computer.
Looks like a nice accessory.
To the average A driver it would certainly improve the feeling of rocking sideways on the shackles.
The thing about this accessory panhard bar, is if it breaks , the car will only revert to what it was before.
If it bends it would just pull the diff sideways a bit, no big drama.
3/4 inch dia is quite OK.
Some here have mentioned they don't like the word wallowing, but that is the term I use , if you were driving with tyres of 10 PSI around a corner.
The chassis would move in and out of the bend as it moves sideways on the sidewalls..
The rear moves out and you correct the steering then the rear moves back in and you over correct it agian, etc.
This is entirely different to body ROLL.
This is the feeling a panhard bar improves.
Not really much force on an A going around a corner.
What, maybe 1/10th of a G if you are lucky?
