Rear main oil return tube
drill the oil passage? sorry maybe a dumb question. never had one apart yet. which passage are you drilling out and cleaning?
You remove the "galley" plug and then drill out the passage that runs along the bottom of the cap from front to rear. Use a 3/8" drill.
I will add some photos to my previous post late tonight of the process.
Good Day!
Pictures:
If increasing the oil return tube increases the oil flow, is it a good idea to also replace the stock oil pump with a high flow oil pump that some of the suppliers sell or modify the stock one?
David Serrano
ok I see I think now drill out the length ways passage aswell to a larger size ive not had an A apart yet so thanks this helps lots. is that a lead or babbet cap that goes back on the end?
Save the plug when you remove it; they can be re-used. If it is a loose fit, place the plug on an anvil and strike it with a hammer. The strike will flatten it and expand it at the same time.
New plugs are available at some suppliers. Snyder's has them.
A-6327-PL $1.00 / ea.
