C chkolar Junior Member Sep 8, 2013 #1 I was told that there was a way to stop the rear main oil leak by cutting a groove in the babbitt on the lower half and drilling a hole in the groove to drain the oil back into the crankcase. Does anyone have the plans for this procedure?
Lanny Well-known member Sep 8, 2013 #2 This section is for "Questions and Suggestions" to the Editor. You should ask your questions in the "General Discussion" forum here in the Early V/8 section. You will get some good replies there. Good Luck .
