Thanks everyone for your advice on the leaking rear main. We would like to add just a couple more points to our question and see if we can narrow this problem down further. Back when we were restoring the car, we had the engine mounted on the running gears, we drove the car around quite a bit with no leakage problem at the time. Since fully restoring the car, we drove it to several car shows, parades, and around town last year with no leakage. Even the guy who did the body work for us drove it around a bit and had there was no leaking. If the tube in the rear main tube was screwed in too far, wouldn’t the leak have appeared sooner than now? Again, we have blown through the tube and run a wire down and it seems like the tube itself is clear. The new brass shims we put in were from Snyders, and as I said before, we reshimmed and toruqued all three main bearings. Today we took the inspection plate off the flywheel cover to try and determine exactly where the leak was coming on the rear main cap. It appears to be coming from the left side of the rear main cap, about halfway down. Is it possible, that when we had the engine rebuilt, they didn’t cut the groove in the bearing the right direction? Since the car didn’t start leaking till this year, could they have not aligned the bore correctly and in the time we have driven it, its wearing the bearings out more and letting oil pass by? One final point, when we started the car up today, there was not a drop of oil come out. Parked it on a steep embankment in the yard and let it run, the oil poured out. When we pulled back on the level, oil continued to pour. After letting the car set for a while, started it up and drove it back into the garage and not a drop leaked. Does this help pinpoint where we need to start looking for the problem. Cant take the engine back to the rebuilder, unfortunately he died.
