Probably not, successfully. They used to make a special set of "tools" for doing it. There was a doohickey that you inserted in an oil hole in the main bearing journal that was supposed to push the old seal out and then there was an insertion "tool" that was like the "Chinese Handcuffs" we had as kids (you know, the kind you put your fingers in) that was supposed to pull the new seal in. I don't remember anyone having any success with them.
On a real world basis, flathead rear seals are kind of finicky. On the last engine I built, I had used a "new" oil pump from Speedway Motors that didn't provide the oil pressure it should have. With less than an hour on the engine (before I put it in the car), I decided to replace it with a good tested genuine Ford pump. I was extremely careful in doing this, but the engine (that had been perfect initially) still developed a slight rear main seal leak.
Do it right and do it once.
