Bill Edstrom
I just finished getting my engine rebuilt with a new B cam, new crankshaft, and a Synder 5.5 head. Last week i went on a tour with the Up North Wisconsin, club. I had about a 150 miles on the engine at the start of the trip. The engine ran great during the tour execpt on the way back after 700 miles on the engine. The engine just stopped running at an intersection and then started after just sitting there. We then drove about 50 miles to a lunch stop where I took time to check the wiring and found a loose connection at the amp meter But before we got to the lunch stop I stepped on the brake to slow down and there was a loud backfire which I think was probably caused by the loose connection reduceing the spark voltage and causing incomplete commbustion. Anyway at the lunch stop the is oil running out of the fly wheel hsg like the BP oilspill. I checked the oil and I was a quart low so I added a quart of oil and we drove about 40 miles to a cheeze mart where we stopped and the oil was still runing out and I was low on oil again so I added another quart and requested that we stop in about 40 miles so I could check the oil level and replinish it. At stop the oil level was full and remained full for the next 100 miles when I arrived home. There has been a little oil from the hsg that has drained on the floor but nothing that is alarming.
I sorry for the long story but I thought it necessary to provide at much information
as possible. I suspect there was blowby which increased pressure in the crankcase forceing oil out thru the rear main. Could the backfire have caused a blowby that would cause this much leakage? Could someone tell us how blowby occurs? I would think that after 700 miles the piston rings would be seated.
I don't want to drop the pan to check main but of course I will to inspect it.
Any help to understand what happened will really be appreciated. Thanks
Bill Edstrom
Bill Edstrom
