Ron in Quincy
A Question for Engine Builders !!!!
Back in the early 60's when A engines were easy to find and cheap; I took several apart looking for a crankshaft that would clean up .010 -.010. On two of the engines I found the same modification on the rear main bearng cap: in front of the rear main thrust, at the end of the existing oil groove, another oil groove had been cut vertical across the cap, at the bottom of this groove was a 3/16" hole which had been drilled into the oil return passage. It apperaed the excess oil flowing toward the slinger would start to exit through this hole and any oil that got by would be picked up by the slinger.
About 10 years later, in the 70's, a friend of mine had pulled the engine out of his 30 coupe to replace it with a B engine. The A engine he removed had always had an excessive oil leak from the rear main; he was going to install the A engine in a Speedster he had just completed. I suggested to him we pull the pan and check the rod and main bearing clearances before we installed it in the Speedster. When we got the pan off and checked all the bearings most had .0015 and the rear main, as I recall had .0040, we corrected the clearance to .0015.
I mentioned to him about the modification I had found on a couple of rear main caps ; he said lets do that to this engne and I did.
That A engine is still in that Speedster, has gone thru two different owners. I recently was talking to the present owner and asked him if there had been any problem with oil leaks ? he said " not a drip"
Would some of you engine builders please comment on this modification to the rear main cap, good or bad ?
Thanks, Ron
Thanks, Ron
