Rear Lower Trunk Panel
nb141fd
Does anyone know if any of the vendors sell a Coupe rear lower trunk panel with the correct arch built in? I've looked for an original but so far no luck. On a 30-31 coupe this panel is taller in the middle by about a 1/4" compared to the ends. I believe most of the reproduction panels are straight across both top and bottom and need extensive work to fit properly. TIA
Tony
I’d check with Bert’s on an original
However, I am currently completing a buck/template to make them correctly
Made a first run yesterday and have to make some minor adjustments
These have the correct arches etc. I have several originals to knock off from
Should have them in two week if all works out. Will be $95 plus shipping to wherever
These fit 28-29 coupe and all cabbys
If any interest get back to oldbluoval@gmail.com
Had a problem with repro panel being straight across the top. Could't find a good original replacement, but did find a bad original from which I took the top reinforcement bar and spare tire reinforcement and installed same in place on the repro panel which solved the problem.
I tried the same thing. It sorta worked but the repo I had was too short and the gap at the base of the deck lid was too wide
That’s why I went the path of making them
We shall see how it goes
