Gufshoz
Why is it that what appears to be a straight forward, simple fix can open up head-scratching problems? Help and suggestions wanted.
I have tube shocks on my '30 coupe that are supported by steel plates that are through bolted to the backing plates. While doing a routine lube job, I noticed that the lower part of the rear, driver's side shock was missing the bolt and hanging loose. In my mind the job should be to simply remove the hub and replace the bolt. Right?
I disconnected the parking and brake rods to facilitate removing the hub with a hub puller. After replacing the missing bolt on the shock support, I attempted to reinstall the hub. The hub will not turn now and I haven't yet tightened the axle nut to torque. The brake rods are still disconnected and the brake adjusting wedge is completely backed out.
I removed the passenger side rear hub to compare it and I don't see any difference. I'm stuck...literally.
