Can the rear hub seal be replaced with just basic tools? Or do you need specific tools to do this? I have a leak coming down the outside of the backing plate which I dont believe is brake fluid. But of course wont know until I pull the Drum off. cheers
Just hope that the axle seal is bad and not pitting on the axle housing surface. Also check that differential lube is not over full, like all the way level with the fill opening. Should be about a finger width below that.
