wmws
Yes that parts cleaner is fine. To just clarify what Y-Block said the taper should be toward the differential and toward the axle. I think you have it right in your last picture. It looks like something has been rubbing on the parking brake actuating arm pin. It may just be the picture but it looks shiny. Maybe that is why the shim was put in. If the end of your axle threads are worn at all be careful not to over torque the nut. I usually go to 90-100 Foot pounds..
