I have a B trans installed in my model A frame. I am surrently using the stock rear mounts with a spacer added to take up the width slack and the holes in the stock mounts are slotted to match up with the wider spacing on the B flywheel cover. I feel like a little extra support at the rear of the trans would be good and notice there is a component that comes with the float a motor kits that must mount somewhere on the center cross member and then down to the rear of the trans. For the life of me I cant find a pic of this component installed. Does ANYONE have a photo of this (preferably with the body off) so that i can see exatly how it fits so I can determine if it might work for my B trans or whether I could modify one or maybe make one myself.
Attached is a photo of the component I am referring to.
Thanks,
Scott
Thanks,
Scott
