rear fenders coupe
'28 & '29 are narrower. I once owned a '29 5 window & a '30 5 window. After Ford's redesigning, in '30, they were almost like 2 different cars. Most body parts won't even interchange.
Bill W.
The cut in for the splash apron.
The 30-31 has deep curved bend L shape.
The 28-29 is a shallow curve.
They are obvious from a distance. I have attach a picture of a 30-31 cut in.
There is also the real early 28 they have a different radius at the splash apron. of course they are rare.
The 30 fenders are longer and more flair on the rear of the fender, along with a bigger radius at the splash apron.
What Kevin in NJ stated is the way I tell the difference when looking at fenders at swap meets. Once you see the two splash apron cutouts, it is easy to differentiate them.
Rusty Nelson
A friend frequented the dry lakes in the '50's & said the '28 & the '29 were the car of choice, as they had less frontal area & better front end aerodynamics. On full fendered cars, the bat winged front fenders on the'30 & '31 cars, would cause lift & you would literally "FLY"! Claude had experienced this, on a LOOOONG, STRAIGHT, downhill!!
thanks guys, that clears that up..... now gotta go swap shopping....good to hear bill is back around helping, with his dog ,too......thanks kev in nj..and all the rest
