Rear fender support bracket
MickyD
Need a picture of the rear fender support bracket for a 1928 model a roadster. I keep seeing 2 versions one square and one round . I believe the square one is for the front fender and the round one is for the rear fender. I am missing the ones for the rear fenders.
1928 should have the forged brackets. Make sure you get the ones for a roadster as the fenders are wider than sedans, phaeton, etc.
model-a-ford-rear-fender-brace-cast-iron-coupe-roadster-pickup-28-21541-1.html
Forged is the "round ones" vs. stamped. The fronts were forged as well for your car. The front and rear are the same style. As mentioned, there are two widths of rear brackets, one for roadsters, coupes, pickups (probably some others) and then a shorter width one for sedans.
It all depends on the fender "reinforcement" that is welded too the inside of
the fender were the 1/4" carriage bolts go through. Is it a flat plate OR does
it look like a "dog bone" about 2" long..?
Got photos...?
