On most banjo housing the ring and pinion tooth counts were stamped at the factory on the bottom rib. You divide the bigger number by the smaller number. In the example above 39 divided by 11 equals 3.54. Common numbers are 9 with 34 which is a 3.78 and 9 with 37 which is 4.11.
