Planojc
I drilled the top of the axle housing, not the torque tube and used an air hose to blow away chips as I was drilling. This is where Ford vented their cars when they went to open drive shafts.I have the Mitchell overdrive with a small leak at the differential and will install the vent that Planojc talked about. The trick will be to keep the chips out of the torque tube. Shop vac? Big magnet?
