Rear end swap
frank long island
Now that i have the 64 ranchero almost done i'm thinking of swapping the rear to a disk from an older explorer also changing the front to disk even though it's only a 6 cyl because i cant find wheels i like anyway will this rear work if not what options do i have thanks i've updated my profile pic's take a look
The rear will work if the length is ok. I doubt the spring pads will line up so you will have to add new ones. If your lucky, the emergency/parking brake cables may bolt up. There is the possibility that you will have to get a longer drive shaft or may have to shorten yours.
