Mart
Well anyone that regularly sets up rear ends - I take my hat off to you.
I was following Capn Kirk's thread http://www.fordbarn.com/forum/showthread.php?t=204079&page=12 and was taking interest because I am doing a similar job.
Well I did what was quite a simple job. I replaced the bearing surface with a bush. That came out well, I posted about it. I then decided to change out the gears. No probs, but I found one of the side bearings was shot so I got a new one locally. Fitted that today, bolted up the carrier and started the shimming process to get the preload right on the carrier bearings. That took ages. Probably about 10 rounds of gasket swapping. Luckily I had bought the gasket set. Ok, then the pinion was fitted and the preload set. It seems tight to me, but does about 1-1/4 turns doing the spin test so I think it is ok. If I had an inch pounds torque wrench I could have been a bit more scientific.
I got that so I was happy with it and test fitted it all back together. The backlash seemed a bit too much, so I made an adjustment, basically by swapping the gaskets from one side to the other (3 thou between the two). That got it feeling ok.
I just finished bolting the side bells on fully. It took me about 6 hours some of which was setting up the axle in a position to work on it.
Like I said, I respect people that do this job. This was my first time. I would probably do it again, but I just wanted to say it took a lot more trial and error and assembly and disassembly that I expected.
I read the procedure by Tom Endy and found it very helpful.
Mart.
Mart.
