frank long island Well-known member Jan 30, 2023 #1 pulled this rear out of a 65 mustang 8 cyl can anyone give me some info the tag reads k cz-f1 3 00 8cd 931 thanks
KULTULZ Well-known member Jan 30, 2023 #2 Are you certain you read the TAG correctly? EDIT - WCZ-F1 1965/70 MUST 8" RG 3.00 OPEN 28 SPLINE Attachments REAR AXLE ID CODE - 1965-1972 FORD.jpg 20.3 KB · Views: 76 Last edited: Jan 30, 2023
rotorwrench Well-known member Jan 30, 2023 #3 The 8-inch Ford axle was used for most of the early small block Ford V8 applications. The 3.0:1 ratio was likely for an automatic transmission car. The Ford 6-cylinder cars used the 7.25" rear axle with the 4-lug axle shafts. Last edited: Jan 30, 2023
