rear end clearance
flathead30
9" Ford rear end in a 1930 Tudor hitting leaf spring Ubold/nut. Can coil overs be added to get better clearance? Any other suggestions??
I'm sure you can. Bear in mind that the more spring you add the stiffer it'll get. Adding a leaf or two to the spring pack would also probably work. Changing the shackle mounts would also work.
Thanks for the input. A little stiffer ride won't be a problem. I looking for as little major surgury to the problem as possible. Any suggestions on where or who would have a "booster spring"? Thank.
