Be careful with the rear radius rods. With the "skinnier" rear, two things will happen. The front ends of the rods will move in and sort of cross each other instead of coming up to the sides of the lug on the torque tube. Then, if you heat them up at the rear to get the angle right (you'll probably have to heat and bend the lug on the front of the rods too,) you'll find out the the bolt holes in the front of the rods will be just a little forward of the hole in the torque tube lug. (I'm coming up on a similar situation- adapting later shorter radius rods to a '40 rear.)
