Rear eend gear oil
90 wt gear oil is recommended for a stock rear end. If it has been converted to posi-track, you will need to add a tube of posi-lube. Does not matter what the gear ratio is.
the climate down here is hotter than where you guys live, so I think I should use the 140 wt. thanks for the info. Al
I use SAE 85W/140 for south Texas climate. Northerners can us the SAE 80W/90. It's getting harder to find the straight grades. I have to buy SWEPCO 201 SAE-90 for the Robinson helicopters due to there specification for straight grade only with a blue color so you can tell it's in there. That stuff is more expensive than the SAE 85W/140 at the local lubricant supply distributor we use.
I can't remember how good my memory is. Gear lubricants are EP rated for the content of extra pressure additives. Rear axles generally have no phosphor bronze bushings unless they are very old worm drive types so it really doesn't matter what EP rating is used. Hypoid type axles really should have EP5 if they are used a lot for hauling heavy loads such as in a large car, pickup, or a large truck otherwise an EP4 would work.
Transmissions from the early ford years have the soft yellow metals so they should use EP4 or less to prevent acidic deterioration of the soft metals.
