I have a 31 roadster with a full rear bumper. The current assembly configuration per side is; (1) trunk mount bracket, (2) bumper arm, (3) cross brace.
When looking in the Bratton catalog, in the description for the bumper bracket that is used for the bumperette (short bumper) is a note that states that the short bumper bracket is used as a spacer when the full bumper is used. It instructs you to trim the bumper bolt eye that would otherwise be used for the bumperette bolt.
I talked to Walt Bratton and he didn't sound too convincing even though it is stated in his catalog. He mentioned that he "...guessed that it could be used that way as a spacer".
My questions are;
My questions are;
- was there a spacer originally used for the full bumper applications?
- if a spacer was actually used for the full bumper applications, is it correct to trim the eye off of the bracket and use this as the spacer bar?
