klicker
I posted a couple weeks ago about a grabbing brake. Finally able to borrow a hub puller. Found what appears to be 90 wt oil in hub cap, and bearing area of drum was full of it. Bad seal apparently? The wheel cylinder doesn't appear to be leaking. I've read a lot of posts from searching.... still confused. Is there another seal inside the axle housing? Or just the seal in the drum that seals the bearing?
Also, I read that there is a fiber washer that goes under the axle washer/nut. Mine didn't have one (39).
My bearing surfaces on the axle housing look great, and my drums have plenty of meat, so not all is bad.
Also.... the threaded end of axle is bent to one side.... nearly the angle of the axle taper! How can this happen? And what do I do?
