Res731
I took off the rear brakes and I found what appears to be rubbing of the shoes and ebrakes against the drum. A few questions.
1 Will a shim on the axle fix this?
2 can I still use the drum if it’s within tolerance? I have some grooves it it now from the brakes
3 I had alot of grease and grime inside the cavity,does this mean my oil seal on the axle housing needs replaced and can I do that without doing a whole overhaul on the transaxle I really am not up to the preload etc steps.
I will try to upload pictures. It gave me an error on first try
