Rear brake return spring just flopping around
billybronco1
There is a spring on the outside of the backing plate on each side for the emergency brake. It looks kinda like the pic attached but is straight on the ends. They are just hanging on the arm an I see no way to attach them or ground them so they will put pressure on the arm. I'm not sure if they are broken or what.
This isn't a very good picture, but does show the spring and the end looped around the arm. The straight end rests against the support shaft for the service brake. The next time I'm at the Gilmore, that would be a good chance to get a picture of the top side showing the other end of the spring.
They are sold in pairs, there is a left and a right. They are mirror images to each other. They are not an easy installation. A number of techniques and tools have been developed. If you have never installed a set try to hook up with someone who has. The first task is to figure out which is left and right.
To make matters worse there are some poor reproductions on the market. I have encountered some that were too short.
Tom Endy
I found it simple to just use a loop of twine to pull the spring back and over the arm, then just pulled out the string. only takes a minute each side.
I used one of these. Still not an easy task, and certainly took me longer than a minute each side. Both of my springs were broken, so didn't have much opportunity to see how they are suppose to go. Fortunately, the new springs were marked "Left" & "Right".
If you were working in the River Rouge plant when your car was made, how fast do you suppose you had to do this task
Okay got it done - it is quite the challenge, I used a flexible wire cable with a loop at the end, pliers and screw drivers - thanks for the tips
I am replacing broken springs and the bands. I was trying to hook the spring before I had the lever on the shaft and the bolt inserted. Bad idea! Thanks for these tips.
