Colorado Greg
I'm installing the rear backing plates with the brakes shoes and emergency housing and I'm having trouble getting the arms through the hole and the assembly on the axle. There must be a trick that I'm missing. I followed Les Andrews book and assembled everything before installing on the axle, but now it won't go on. Any tips would be greatly appreciated.
I also have a question about the emergency return spring on the backing plate, I know one end of the spring sits against the housing and when I hook the other end onto the brake arm, it just seems awfully tight. Is this supposed to hook onto the arm or the bolt?
This is for a '29 Coupe, Thanks for all of your help!
Greg
Greg
