Res731
I purchased new camshafts for the rears and reusing the existing service brake arms. After assembling with the rivets I discovered I forgot the dust ring.
So I dissembled and purchased the dust ring. Problem is when I try to install, the service arm is binding when i try to spin it. Anyone run into this before? Should I grind down my service arm to eliminate the binding or drill out the rivet hole?
i have the same issue on both sides.
Thanks
Rudy
Thanks
Rudy
