Aok
Have a problem with the rear brake adjuster wedge it turns but does not seem to click in like the other side not sure if its the wedge or the threads, rest of the brakes look good.
Do I have to remove the shoes can I just remove the wedge.
2nd question to remove the entire rear brake unit after I remove the 4 bolts that hold the housing do I also need to remove the arms that the brake rod connect to. I have the em brake shoe off and 4 bolts loose but it seems like the arms that connect to the brake rod will also need to come off. Was reading the les andrews book and it just said remobe the 4 bolts but the arms seem to hang up
