Clem Smith
My right rear axle seal leaks oil onto tire, rim (and brake?).
Can I change axle seal without removing rear end?
Real Axle Question...During regular 500 mile maintenance, how many lube squirts normally go into the wheel bearing fitting on the backing plate? No indication it is full like a tie-rod.
Remember, Tom,Normally I start the car ownership by removing the drums to check the brakes. While the drums are off I clean and repack the rear wheel bearings just as I would do to the front. I use Mystik JT-6 High Temp grease and figure this will last until I need to pull the drums again.
If you pump grease in the zerk, I'd stop at about 4 pumps, but then I also don't know for sure where those 4 pumps of grease went.
