I need to replace both rear axles on my inherited '29 Roadster, due to bad keyways. The rest of the rearend seems ok (no strange noises).
I have sourced some new (old) axles with good keyways. Can I change out just the two axles (using new axles with existing ring/spider gears), or is it better to change out the whole existing axle assembly (2 axles, ring gear, & spider gears), with the new sourced assembly (which I do not know its running history as it was a junked parts car).?
Any other heads ups would be appreciated as I'm new into this ongoing process of finding things that need fixing. I'm hoping to not have to rebuild the whole rearend if possible.
