Thanks all for the replies. I will be verifying using the methods suggested. I did check the underside of the pinion area as suggested and it appears 11-39 is stamped on the rear axle. Photo below.
If it is indeed a 3:54 axle ratio, I guess no need for an overdrive. As most of my driving will be around town and rural.![]()
