Bob you are an experianced Model A person,where did you get the theory that the key drives the wheel.
The first Model T s used a key to drive the wheel and had to change to a taper because the key failed.
All my machine tools are driven by a taper, no keys.
Try this experiment. Remove both rear axle keys and drive your Model A.
If you were to remove both keys, the car would still move if the rear axel is torqued properly. If not Bob’s comment is correct. The axel would start turning inside the hub.
