Rear axle and grease
31 ford
Once the rear drum is removed via a drum puller , should the tapered exposed rear axle be coated with grease including the axle key before re-installing the drum ? Thank you for your advice .
NO! It is a dry fit.
Please ask your questions on the forums page not in this section. This section is for questions about the site not car questions.
