Howdy boys, reckon I'll ask this group also. What size reamer do I use for the following; King pins, rear brake cam, oil pump, dist., front brake actuators, and brake and clutch pedal? Thanks guys!
I have a Snap-On adjustable reamer and an old .814 king pin reamer.
My question is, I seem to have trouble setting the adjustable reamer correctly. Meaning, when I measure the sizing, it fluctuates enough with the slightest movement of the caliper that it's out of spec.
When measuring an adjustable reamer, I'm assuming you want to measure the outer most edge of the cutting blades for the correct sizing.
Any tips for setting up an adjustable reamer would be greatly appreciated.
Thanks,
Tim - I'm not a huge fan of adjustable reamers either, but they do have their place. I never mic an adjustable reamer and then use that as the actual dimension. Instead, what I do is set the reamer well below what I expect is finished dimension, run it through, burnish the hole lightly to get rid of high points, and then measure the diameter using either gage pins or mic. If it's still too small I increase the diameter of the reamer slightly (say 1/4 turn of the adjusting nuts) and repeat until I'm satisfied. Keep track of how much the diameter of the resulting hole increases as you turn the adjusting nuts and that will give you an idea of how the reamer reacts. It's slow, yes, but if that's what you have to work with, you need to take your time.I have a Snap-On adjustable reamer and an old .814 king pin reamer.
Thanks,
Thanks boys, I always enjoy a little discussion about things like this, when there are several differing opinions. All are good! My preferred choice in fitting bushings is by honing, which I believe can be done with good success after reaming. I'll probably be proven wrong, but that's how I like to do it. My experience with reaming has always been on the not so good side, probably due to my inexperience in using them correctly, that and the ones I do have are probably worn out. Thanks for all your responses!
If you have a couple different pieces to do, then by amortizing the costs over several pairs of spindles, you will have a MUCH better job of fitment at likely a cheaper price than the purchase of a good quality reamer.
Thanks for the advice Brent, however, automotive machines shops just don't exist here in Eastern Oregon as they did 30+ years ago.
I have a 0.814" spindle bolt reamer (AKA King Pin reamer) that no longer cuts. Can it be sharpened to not less than 0.810" diameter?
