Really Cool Old & New Stuff
Ian1932
Radiator closed up since 1951. Old new parts. This stuff has been tucked away for a long long time...Some new shocks from Bill Stipe...
Anyone know what the item is that says 1933 on it?
more
I'd say the item with 1933 embossed on it is part of a tool to be used to remove
and install rivets on brake linings.
Peter
New radiator is not an original Ford, Ford did not make honeycomb radiators. Still a very good radiator. No wonder 32-4 parts dried up around here after the 50s, looks like you got them all.
As jimTN idicates, the radiator is NORS, not NOS. You could put it to good use on your roadster and hopefully have a straight fin and tube original for your coupe project.
Thats a bummer...I will put that in the roadster. I found 2 more, which i believe are for a B...I think ill leave them both where they are until the times comes...I see one more but i cant get to it...
If they are for a "B" they will not work as they "should" only have "One" "inlet" and "outlet". SO not sure what you trying to indicate by "B" but on here a "B" is 4 Cyl.
I meant i think they are for a model "B" / 4cyl, meaning they are probably not what i need. I have another that i cant get to because i will need to move half of the earth to do so. I am hoping that the one "i cant get to" and do not have a picture of is for a V8...
I have another 32' that will be bone stock. David was just saying i could use the repo in the roadster and hopefully i had another true Ford rad for the other car (coupe) that will be stock.
