Ready to install Burtz engines
Del in NE Ohio
Columbiana
OH
Price
In ad
Prus Engine & Machine in Columbiana, OH has a Burtz engine that has been test run and is ready to install. This engine has Burtz HC head, Burtz cam, Balanced Burtz flywheel/clutch/pressure plate assy, Nettles oil pump made specifically for use Burtz engines.
On test stand, this engine sounds like a Model A, but you can tell it has “attitude “. At idle it has 10# oil pressure. Oil pressure maxes out at 42# with NO LEAKS.
You will need you manifolds and carb, distributor, water pump and flywheel housing. Shipping is available.
Price is $10,500
At present we have one motor ready to deliver and three more awaiting completion.
Prus Engine & Machine has been rebuilding Model T and Model A engines for well over 30 years. We are well known in the Model T world for our high-compression Model T head.
Leave PM for contact
