G
Guest
Guest
Re: Polarizing at the regulator more than once?
Sounds like you have a bad starter. You only need to polarize the generator when you have replaced the regulator because it was defective. The gen willmaintain its polarity unless the cutout sticks and caused it to loose its polariy.
You should be using 0 gauge cables. 1 gauge is a little light. The starter armature should have no side play and very little end play. The starter should also have the brace at the front that connects to an oil pan bolt.
